Page 2 of 6 FirstFirst 1234 ... LastLast
    Little machine shop can now suck my plums!
    Just had a new 2mm flat 4fl endmill delivered.
    Out of the box and broken in 3 minutes!
    Sent from my F8331 using Tapatalk
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by Dave_stoke View Post
    What speeds and feed? What material?
    4 flute?
    4 flute?
    Exactly this Click image for larger version.
    Chaz's Avatar
    I wouldnt be using 4 flute for brass / alu. 3 at most, 2 is better. Did it snap on first engagement or did it cut for a bit?
  5. #15
    It got this far but very aggressive. I suppose I should have dragged the feed slider down. But a calculator should be accurate no?
  6. #16
    Chaz's Avatar
    From the pic, it looks like you plunged directly into the stock or did it do a helix down? If you plunged then that would be an issue, not the best way to engage a cutter into material. When I cut at new speeds I turn the feed down to 10% and then ramp up once I have done the helix down and then started to make the cuts I expect. Sound / vibration / noise is key.
  7. #17
    It's actually a helix entry.
  8. #18
    Chaz's Avatar
    Material looks a bit gummy. Did it clog up the bit? Id say 4 flute is to blame here (IMHO / 2p).
  9. #19
    Honestly I started with 4fl when I got the machine, this was done with 4fl 2mm a while ago. But without using the calc
  10. #20
    Chaz's Avatar
    To me (and the pics arent very clear) it looks like the tool lacked lubrication and/or ability to clear material fast enough. A 2 flute is more forgiving.
  1. Help with speeds/feeds please?
    By examorph in forum Tool & Tooling Technology
    Last Post: 29-01-2017, 01:54 PM
  2. Speeds and feeds
    By eurikain in forum Workshop & Equipment
    Last Post: 26-03-2016, 06:00 PM
  3. Feeds and speeds software?
    By Leadhead in forum Computer Software
    Last Post: 31-10-2015, 09:34 PM
  4. Feeds and speeds
    By dudz in forum Tool & Tooling Technology
    Last Post: 26-08-2013, 11:42 AM
  5. Speeds and Feeds
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 20-09-2012, 01:38 PM
