Thread: Odd behaviour when engraving.
This problem is fixed.
I went on the Fusion 360 forum and posted about the problem. A lady called Julia replied and suggested I send her my file for her to look at. i did send it and she replied the next day. It turns out that by changing the setting tolerance in the passes section of the engrave cam menu ( fourth tab from the left of the box ). It was set to 0.01 and when changed to 0.05 it works fine, the toolpath now covers all the letters and numbers.
I guess the lettering was so small that the tolerance was not allowing it to do certain cuts, I am thinking that it was more the closeness of the gaps between that was the issue. Anyway problem solved, I will now be aware of the importance of the tolerance tab.
I may still end up getting Vcarve desktop at some point. Its a case of right tool for the job I think, for more 2.5 d engraving type stuff it is just quicker to get it done on Vcarve.
Fusion is fantastic though for more complex 3d stuff you can`t beat it.
Ollie
The Following 2 Users Say Thank You to Ollie78 For This Useful Post:
27-03-2019 #2
The Following 2 Users Say Thank You to AndyGuid For This Useful Post:
27-03-2019 #3
Without this forum I don`t think my machine would be working at all.
Thought it should make good reference if someone else searches for it.
Ollie
The Following User Says Thank You to Ollie78 For This Useful Post:
Odd behaviour in LinuxCNC running Fusion360 code
By Wal in forum LinuxCNC (EMC)Replies: 2Last Post: 27-01-2019, 10:46 PM -
Weird NC Studio behaviour after manual tool change
By WRandall in forum Chinese MachinesReplies: 1Last Post: 27-07-2018, 10:47 AM -
Odd 2d pocket behaviour
By Davek0974 in forum Fusion 360Replies: 4Last Post: 06-01-2018, 06:27 PM -
Noise, Interference, and unexplained electrical behaviour
By g4ghp in forum General ElectronicsReplies: 4Last Post: 24-04-2014, 11:39 AM -
Odd PC behaviour
By Wobblybootie in forum General ComputingReplies: 14Last Post: 01-12-2010, 02:32 PM
