23-01-2010 #1!I slap in a 6.5mm drill - it bends about like a bendy thing in Bendy Convention.
in ally???
Are your drills sharp? Is the lathe turning in the correct direction?:rofl:
Is the tail-stock aligned correctly?
Drilling a hole in aluminium should not cause you any problem. Similarly, if your boring tool is sharp, it should easily cut a clean hole.
What depth of cut are you trying?
23-01-2010 #2
Dril bits were brand new (they are jobber bits - cheap as chips, but I figured on throwing them away and starting with a new one very regularly)
Yes the lathe is turning in the right direction (BTW, I'm not offended - it's a valid question with someone new like me!)
Re the tail stock alignment - this (I think) may be the root of my problem - how can I check it's alignment to see if it's within tolerance?
Thanks.
23-01-2010 #3
FOR SALE: Denford MIRAC CNC Lathe. Single Phase. Absolutely complete and perfect running order.
By Nick Butler in forum Items For SaleReplies: 19Last Post: 21-08-2013, 11:20 PM -
a perfect 90deg joint - 15mm Alu
By dsc in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 24-02-2013, 01:31 PM -
Not cutting perfect right angles and sticking on Y axis ?
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 10-12-2012, 09:41 PM -
Increasing timing pulley bore size from 3mm t0 3.175mm
By divdav in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 14-05-2011, 09:45 AM -
help needed drilling bore hole in mxl timing pulley
By geekinesis in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 02-02-2011, 01:07 PM
