Thread: Tool height sensor.
17-06-2019 #5
Well, I am trying to find out the issue with little success.
Today I cut two ferrite beads or rings or whatever they are called from the wire on an old xbox 360 controller. I disconnected both the wires to the probe and wrapped a section of each wire through and around each ferrite ring in the hope this may reduce interference as suggested to me.
To my initial delight the first time I tested it the touch probe worked as it should, so I thought it was fixed. A bit later I went to cut a small project and started to set the work zero`s attached the clip and clicked the auto z button, I was prompted to tap the plate on the bit which I did. The screen said it had registered the tap or something to that effect, then immediately the same pop up came on saying the probe is active.
Now after trying a few times I couldn`t make it work again (tried swapping wires over, restarting everything etc). The probe lights up the correct led on the diagnostic screen.
I noticed a flickering light on the diagnostic screen really quickly flickering off and on. It was PORT #2 01. Could this be what is causing my interference ? And what is it ?
So one step forward and two back.
Ollie
Tool change height cannot be changed - Bridgeport Interact 520 VMC
By Wildblood7 in forum Bridgeport Milling MachinesReplies: 0Last Post: 07-11-2018, 11:20 AM -
How to use the tool height probe sensor?
By jhonansaro in forum Laser Machines & BuildingReplies: 4Last Post: 04-05-2018, 09:21 AM -
Help Please With Auto Tool Height Mach 3 Problem
By howser37 in forum Probing, Digitizing & ScaningReplies: 26Last Post: 12-06-2014, 07:55 PM -
Z AXIS, big tex blue screen and auto tool sensor Problems
By Tomnewry in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 01-01-2014, 09:01 PM -
Tool Height Setting Probe - Mach3 - solution
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 18Last Post: 12-11-2013, 06:23 PM
