Much depends on how much you want - I've always bought mine from CPC - they sell 0.75mm^2 by the metre which is probably too light-weight for a 2.2kW but I've never had any problem with it - plus I live about 10 minutes drive from their trade counter. The usual suspects (Farnell and RS, etc) are likely to sell by the reel which may make things more unaffordable depending on your needs. Google is your friend, CY is not rare.
17-10-2019 #2
0.75mm2 ought to be OK, the tables I've looked at give it a current rating of 12A @ 30deg ambient which even at 220V is enough if the power factor is anything like reasonable. Farnell do (suprisingly) sell CY by the metre, not the cheapest but if you have an account the shipping is v. reasonable which can tip the balance. If you want something extra flexible Rapid electronics do a good deal on Lapp stuff.
The Following User Says Thank You to Voicecoil For This Useful Post:
Porter + Cable spindle
By kell in forum Items For SaleReplies: 3Last Post: 26-06-2021, 12:10 PM -
Spindle cable a bit stiff??
By Voicecoil in forum General ElectronicsReplies: 4Last Post: 09-09-2019, 09:42 AM -
Which thickness CY cable do I need for 1.5kW spindle?
By bee in forum Generic Chinese SpindlesReplies: 44Last Post: 19-03-2017, 08:43 AM -
Where to buy 12 multi core flexible shielded cable for encoders ?
By Boyan Silyavski in forum Marketplace DiscussionReplies: 8Last Post: 31-08-2016, 11:07 PM -
1.5 kw Chinese spindle cable
By 142victoria in forum Generic Chinese SpindlesReplies: 4Last Post: 02-11-2015, 09:53 AM
