Thread: Three phase motor choice
16-12-2019 #2
I would be interested to see a link (are you thinking Jianken?), but I got the impression the good ones were expensive and still lacking a bit down low. I'd happily settle for a free Mechatron like Marco Reps...look like usable performance from their 2.2kW unit from ~5,000rpm.
Full disclosure, I do have the spindle I intend to use already - if it proves a massive mistake I can swap on a different spindle later with minimal fuss. Hopefully the picture makes the point (I tried to keep the perspective fair) - it's obviously much bigger than a basic 2.2kW Chinese jobby, but not that big...80mm vs. ~110mm...so also a bit bigger than a basic 3.0kW unit (though obviously unpowered). Consider that a decent amount of the stickout is that particular toolholder, the tidy integral mount (and unpictured belt guard), 30 taper tooling, hydraulic drawbar release, reassuring derating (from 7.5kW / 20,000rpm), I can change the gearing, and that it's rated for use from 0 rpm (though I wouldn't be that mean to the bearings). Cheap, simple motors and VFDs appeal too. I'll concede it's heavy and air-cooled.
I put the 7.5kW / 8000rpm motor I took off of it on the floor, and now I can't pick it back up!
16-12-2019 #3
You can do that with any induction motor, as it's what happens when you run out of volts to drive the motor at the intended speed. It is however actually a good way to maximise low speed torque, while still getting a high speed, as you're not as likely to need full torque at higher speeds for a low of machines.
The problem is, you can't break the basic rules of physics.
If a motor coil is rated to handle 5A, you might be able to push a bit more current through it, but push too much and it'll melt. It doesn't matter what voltage you use, if the rotor stalls, it'll likely melt.
And as Torque is direct result of current, you can't magic up more torque without pushing more current.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Help with VFD paramaters to an old 3 phase motor
By RobC in forum General ElectronicsReplies: 1Last Post: 05-02-2019, 12:11 AM -
WANTED: 2.2 KW 3 Phase Induction Motor
By Chaz in forum Items WantedReplies: 5Last Post: 23-11-2017, 06:18 PM -
Please help me with step motor choice.
By Toolman321 in forum Stepper & Servo MotorsReplies: 2Last Post: 08-06-2017, 10:02 AM -
Replacement motor choice for SEM servos on a Harrison M300 lathe
By PeteL in forum Stepper & Servo MotorsReplies: 3Last Post: 03-05-2016, 07:05 PM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM
