Thread: Three phase motor choice
16-12-2019 #2
Mud,
I'm not the expert here but that 2.2Kw (3HP) motor weighs 22Kg before you add the rest of the gear you need to drive the spindle. Most of us here use a Chinese water cooled 2.2Kw spindle that is somewhat lighter and runs up to 24,000 rpm without the complexity of a pulley system and separate spindle. BST Automation (owned by the unlikely named 'Fred') is a well regarded supplier. This link shows you the package...
This spindle includes an ER20 collet chuck which will hold (if you buy a separate set of standard ER20 collets) any tool sized from 1mm to 13mm.
https://www.aliexpress.com/item/7139...348c696fzeIZSW
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Help with VFD paramaters to an old 3 phase motor
By RobC in forum General ElectronicsReplies: 1Last Post: 05-02-2019, 12:11 AM -
WANTED: 2.2 KW 3 Phase Induction Motor
By Chaz in forum Items WantedReplies: 5Last Post: 23-11-2017, 06:18 PM -
Please help me with step motor choice.
By Toolman321 in forum Stepper & Servo MotorsReplies: 2Last Post: 08-06-2017, 10:02 AM -
Replacement motor choice for SEM servos on a Harrison M300 lathe
By PeteL in forum Stepper & Servo MotorsReplies: 3Last Post: 03-05-2016, 07:05 PM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM
