This ^^^^^
Mains electricity is very “dirty” in some areas. Stick a scope on the mains and you would be shocked to see how bad it is at times. It’s the reason if it was me I would at least have a voltage regulator in the circuit at the very minimum. Cleans up that dirty power a treat.
03-02-2020 #2
What are you on about
You can supply a drive with a toroidal, rectifier and some caps ie DC or just use a toroidal and use the rectifier and caps in the drive.
I think you are going overboard a bit here and frightening new users into things they just don't needThat’s why I’m thinking a decent UPS would at least let you shut down safely. Or is my OCD going overboard again?
The Following 2 Users Say Thank You to Clive S For This Useful Post:
03-02-2020 #3
No no no, I’m asking the question of experienced users. I’ve only got experience of an openbuilds machine at present and haven’t had the pleasure of building a larger CNC so the op’s question and your reply about mains fluctuations made me think about running tests on the local power grid.
I can’t remember the figures from my last test but I do have the kit still.
I still remember the time back in Cannock where I was sitting in offices and suddenly the ceiling fans turned into scary propellers. Turned out the distribution centre had supplied twice the rated frequency for a while... blew a ton of mainframe terminals throughout the building and only the fact that it tripped the generators protected the two mainframes we had downstairs (IBM 370/158 and IBM 3033).
That truly is a worst case scenario but check your local power. Mine is ruddy awful at times, especially around 6pm. My oven is flashing the clock timer at me because we had a brownout yesterday.
But ultimately I don’t know much about mains system and I haven’t touched anything 3 phase or high voltage this millennium... so I’m very much the noob asking questions.
Academic research on CAM CAD software/ Help please
By lorenzo0572 in forum CAD & CAM SoftwareReplies: 3Last Post: 03-05-2014, 11:08 AM
