    Actually think to today's while setting up a machine was a good one.??? . . . Couldn't for life of me understand why Mach3 wouldn't Reset.! . . E-stop was set and I'd pushed the momentary Reset switch for drives.???? . . . took me a good minute to realize I hadn't actually turned on the power to control box..
    Well you have to turn the power on to your brain first
    In my defense, I'd only had 1 cup of tea and no Hobnob's so my brain hadn't fired up yet..
    Most stupid mistake was to edit the .ini file in LinuxCNC v2.8 to set up auto-racking on my twin motor machine and then some weeks later run 'Stepperconfig' to change the acceleration. Took me all morning to realign the gantry.
    Well for the benefit of others I think you meant pncconf if you used a Mesa. But anyway stepconf and pncconf should never be used after the initial run as it will overwrite the hal and ini files. Ask me how I know?
    I'm not posh enough to use a Mesa, I'm still using the cheap Chinese parallel breakout board I bought for my first ever 'proof-of-concept' router which was made out of MDF and used allthread for leadscrews. It's advice worth remembering though!
    I like to call this kind of fault "Finger Trouble'. Often embarrasing but it's the cheapest and simplest kind of 'fault' to fix.
    lol
    Luckily I don’t make any mistakes. Anything you see in my videos are done on purpose to show you what not to do.
    .. . think I got away with that one.
    Obviously..
  1. Probably a Stupid Question.
    By Electroconducive in forum Gantry/Router Machines & Building
    Last Post: 24-10-2018, 08:33 PM
  2. Replies: 2
    Last Post: 02-10-2018, 07:27 AM
  3. The most stupid Newbie question ever!!
    By mattscarlett in forum General Discussion
    Last Post: 30-06-2016, 08:09 PM
  4. NEW MEMBER: i didnt think i was stupid but i do now!
    By stone in forum New Member Introductions
    Last Post: 17-03-2013, 08:49 PM
  5. Stupid question I know... but - What size is my Spindle Collet ?
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 25-11-2012, 03:34 PM
