Hi I am looking for a PC based unit because that uses a USB connection its no use changing the format. Out of the 2 for perfomance, reliability and ease of installation what would you recommend? the cnc is a 3 phase unit will that not effect the controller.
16-03-2020 #2
Ok well first let me say USB isn't very reliable for CNC your better using an Ethernet-based controller. Both those I suggested are Ethernet-based.
The AXBB is the easier of the two regards installation because it doesn't require a Breakout board but the UC300 attached to a decent breakout board like the UB1 is the more powerful package and offers more I/O.
Both of the CncDrive boards can use either Mach3 or there own software called UCCNC. Mach3 is very capable and easy enough to use but it's getting long in the tooth and isn't supported anymore which puts some people off. For me personally it's not a problem and it works very well for routers etc I build and sell.
However, if I was using either of these boards I'd use UCCNC because it's fully supported and in some cases better than Mach3.
If I was using Mach3 then I'd us a controller from Cslabs as they are much higher quality and very very reliable.
Regards 3 phase then usually this is just for the Spindle and coolant pumps. The control side will pull from just one of the phases and somewhere in the control box will be transformer or two dropping voltages for drives and Controller, etc.
Obviously, without knowing more about what you have I can't say much more than that.
Tonsen 4 Axis Controller/Bob
By Pointy in forum General ElectronicsReplies: 30Last Post: 18-07-2018, 07:02 PM -
Upgrade to x axis required. MG or HG rail
By marbles in forum Rails, Guideways & BearingsReplies: 0Last Post: 10-12-2017, 01:51 PM -
FOR SALE: leewood 3 axis controller from an isel 3 axis cnc
By nobby in forum Items For SaleReplies: 1Last Post: 24-09-2014, 09:08 AM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM -
Day shift Manual Miller/Night Shift Turner and Grinder Required - Berkshire
By J Maynard in forum Opportunities Available & SoughtReplies: 0Last Post: 06-01-2012, 11:46 AM
