Thread: Stepper motor wiring
02-03-2010 #1
Hi All
Wondered if someone could just check my wiring ! , im using Zap 23size motors , 8 wire to a parallel in a Gecko G540 as im finding wiring diagrams confusing ( ive looked at so many , at one time it looked so simple lol )
http://www.slidesandballscrews.com/p...H88-3008BF.pdf
Ive wired them up as :
A = yell / wht
C = red / wht = A
A- = yell
C- = red = A -
B = green / wht
D = black / wht = B
B- = green
D- = black = B-
At the moment ive got a green light on the G540 until i plug the motor in then it gose straight to red . So the motors wrong or ive got some more fault finding to do !.
Fun ahead i think
If you are wiring them bipolar parallel then
A+ = Red + Yellow/white
A- = Red/White + Yellow
B+ = Green + Black/White
B- = Green/white + Black
I note the Zapp info lists a blue winding not a yellow one, but assuming the other colours are the same then the above should work...
05-03-2010 #3
Thanks Irving that worked a treat , got to have alook at the diagram to see how i read it wrong ...dohhh!
28-03-2010 #4
28-03-2010 #5
you have 4 windings A1 (red) A2 (yellow) B1 (green) B2 (black). When the motor is used as a unipolar the windings are energised in sequence A1 B1 A2 B2, but in bipolar configuration they are energised in pairs A1+A2, B1+B2. The tricky bit is that the windings are wound as opposing pairs so when used in bipolar parallel arrangement you have to reverse one winding of each pair to align the magnetic fields, hence the pairing of Red with Yellow/White etc.
The Following User Says Thank You to irving2008 For This Useful Post:
28-03-2010 #6
Stepper wiring/colour coding
By rwb97 in forum Stepper & Servo MotorsReplies: 24Last Post: 23-06-2014, 11:34 AM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper motor tunning wiring
By handyoodman03 in forum Stepper & Servo MotorsReplies: 47Last Post: 11-01-2013, 05:49 PM -
CY or SY cable for stepper motor wiring?
By Jonathan in forum General ElectronicsReplies: 6Last Post: 26-09-2010, 06:25 PM -
Stepper Motor Wiring (Screened?)
By pequod in forum Stepper & Servo MotorsReplies: 19Last Post: 03-08-2009, 10:15 AM
