    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Sorry Guys, I did edit out the first link. Didnt think anyone would be about . I did search some used printers, but they either had very small build areas or just shit. The Creality 10S happens to be the Only (as you said decent) one in stock and available to ship in NZ during lockdown.
    Cant see ABS listed as an option with this printer ?. Whats the general better material to use for strong parts ?.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
  2. The Following User Says Thank You to dudz For This Useful Post:
  3. #2
    ABS needs an enclosure, simple from cardboard or polystyrene foam, or more complex from wood and glass. You could print simple stiff without a box enclosure but anything complicated will be a 100% fail. Apart from that ABS is weak.
    PETG is the filament that does it all, strong and does not melt from the sun in a car dashboard for example. No good for engine and near engine..
    And when you learn the PETG, Nylon is next as this is the filament for more resistant parts and car parts
    Its absolutely pointless to buy and use PLA. before an year or 2 it was the cheapest and PETG was triple the price. |Now that prices are almost same, there is no point. parts are strong and is easy to print but will melt left at sunshine.
  4. The Following 2 Users Say Thank You to Boyan Silyavski For This Useful Post:
  1. Cheap reliable connectors
    By bluesking in forum General Electronics
    Last Post: 18-06-2019, 10:36 AM
  2. RFQ: Looking for a reliable CNC prototyper in aluminium, for lots and lots of jobs
    By Felix.U in forum Projects, Jobs & Requests
    Last Post: 01-12-2015, 02:00 PM
  3. Wanted - Regular work for reliable machine shop in Northants/Kettering area
  4. Looking for a reliable cheap linear system pls
    By psiron in forum Rails, Guideways & Bearings
    Last Post: 07-06-2010, 04:18 PM
