21-04-2020 #4
Interesting challenge!
I'm not sure Ali will be your friend in this game because it is so soft. Also, it doesn't "work" well - forming 90 degree bends can crack the material unless you have a silly large bend-radius. Maybe steel sheet with something like a scroll-saw with a metal-cutting blade would offer a cheap entry level capability?, next your challenge would be to finish the product - powder coating or similar, can be outsourced.
If you're doing one-ers, then as Jazz says ask for someone with suitable machine to do the cutting for you; if you're planning to do more then you need to be a bit more realistic with your machining requirements and costs.Last edited by Doddy; 22-04-2020 at 12:58 AM.
The Following User Says Thank You to Doddy For This Useful Post:
CNC Cost per hour
By bertthedog in forum General DiscussionReplies: 5Last Post: 13-07-2020, 11:06 PM -
Looking For Cost Effective T Nuts
By AlexDoran in forum General DiscussionReplies: 2Last Post: 25-08-2017, 04:47 PM -
NEW MEMBER: Have investigated ways to make DOS based programs run on 64 bit computers
By 64BitAndForwards in forum New Member IntroductionsReplies: 1Last Post: 26-01-2017, 04:43 PM -
RFQ: Cost request for cnc/routing.
By Conan257 in forum Projects, Jobs & RequestsReplies: 3Last Post: 28-04-2009, 10:55 PM -
2 ways of mounting motor
By Steve-m in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 28-02-2009, 01:12 AM
