09-05-2020 #25
The cutter is a 2mm extended neck ball nose and the 4mm shank is flush with the collet. I have to use a 20mm long tool as the next size down (10mm) is too short. As for the feed rate I run them at the recommended 210mm/min but in this case as the slot is only 2.059 wide I prefer to reduce the feed
Harrison Alpha 330 lathe Fanuc 21it Work offset and Work shift problems
By Sucram in forum General DiscussionReplies: 0Last Post: 15-12-2019, 09:44 PM -
work piece showing outside table display
By terry1956 in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 09-01-2017, 10:36 AM -
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
eBay: NEAT XY-1010 xy table 8" travel very solid 17kg table NEW ebay.co.uk 251715555999
By emlclcy in forum Items On eBay UKReplies: 0Last Post: 12-11-2014, 09:14 AM -
Setting up work on the rotary table
By irving2008 in forum Machine DiscussionReplies: 6Last Post: 09-01-2010, 10:27 AM
