Thread: PSU size calculation
Thanks for the feedback. I've been looking into the suggestions today and am currently leaning towards a toroidal transformer and drives that accept AC so that I can drive motors at 60-65VAC (and am probably also leaning towards the 5.5Nm closed loop motors). From what I read today about unregulated power supplies, this seems like a good option, but I am still learning and have limited electrical experience, but am willing to take it on.
I'm currently searching for a reference design for a toroidal transformer - I'm willing to build one but need good guidance to help with the calculations, components, wiring, etc..
20-05-2020 #2
If you are going with AC drives then you don't need to build anything this is the beauty of AC drives, you just buy a toroidal transformer and pull directly from the secondary outputs. The only thing you need to do is decide how you are going to use the secondary outputs. This will be based on the spec of the Toroidal transformer you buy.
If your not sure what I'm meaning just say and I will explain exactly what I mean and provide a diagram showing how it's done.
Even building a DC supply using a toroidal transformer isn't difficult but does require sizing components correctly to give the required output. But the actual building or wiring side of it is very simple, you don't need to be an electrical Wizzard. Again I will happily help you chose the correct components when you know what you require and decide on using a DC supply..
I've helped 100's of people with Zero electrical knowledge build them so don't be phased it's easy enough.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
How-To: Feed Rate Calculation
By Lee Roberts in forum Machine DiscussionReplies: 20Last Post: 25-03-2020, 04:09 PM -
How Strict is the Max Vsupply Calculation for Steppers?
By mattnedgus in forum Motor Drivers & ControllersReplies: 14Last Post: 02-08-2019, 08:55 AM -
O-ring calculation
By Clive S in forum General DiscussionReplies: 3Last Post: 18-03-2017, 04:54 PM -
pulse equivelant calculation
By yasser in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 17-05-2016, 10:10 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
