28-08-2020 #6
If you Zip up the file and attach it I will take a look. Vectric posts are notorious for spitting out segmented arc's. I believe there may be a post-processor that is available which uses G2/3 arc moves so it might be worth taking a look at which post you used.
Thou to be honest any properly setup router should easily handle cutting what looks like a 10mm radius at 3mtr/min. Who set up the motor tuning, you or RNR.?
I don't know this company or the router but if it's built stiff enough and properly setup then it should easily handle cutting at those feeds.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
My Sound Dampening Enclosure for almost finished CNC Router
By Nealieboyee in forum Woodworking Project ShowcaseReplies: 7Last Post: 24-05-2019, 11:14 AM -
Couple of questions about carriage positioning on X axis and z axis rails
By Richard in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 19-11-2017, 10:16 AM -
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
