29-09-2020 #7
All
Thanks for the info. After further consideration and research, it seems WC may be better suited as I'l be running the spindel for hours a day and I'm looking at this VFD / Spindle combination from th HY store on AliExpress: https://www.aliexpress.com/item/9050...c008xEitI&mp=1
It seems it is going to be a learning curve to programme the VFD and to get it set-up and tuned properly.
As for the comment re: the enclosure - I intend to run dust extraction unit continuously to keep a clean working are and prevent buuild-up of chips which can melt and cause issues. I'll turn my attentoin to the enclosure at a later stage, but I am considering the airflow and sound dampening as well.
Auto sensor XYZ
By Zoprano in forum Chinese MachinesReplies: 1Last Post: 24-01-2019, 09:19 PM -
Spindle position sensor
By GeoffV in forum Motor Drivers & ControllersReplies: 3Last Post: 23-03-2014, 10:00 PM -
Spindle Motor Recommendation.
By cambesol in forum Marketplace DiscussionReplies: 0Last Post: 21-11-2013, 12:15 PM -
Mdx-40 (with zcl-40) Y sensor bar. Help!
By Rastamonk77 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 12-02-2013, 09:44 PM -
Router bit recommendation, spindle speed and feed rate?
By FlightCaseCo in forum Spindles & Drive MotorsReplies: 13Last Post: 03-04-2012, 12:53 PM
