    Quote Originally Posted by John11668 View Post
    Not seeing any illumination on pin 12 as I rotate the disc past the single slot
    I suspect with no resistor you have blown the new optical sensors
    Take the pin 12 and touch it to ground. See if this triggers the pin in mach3
    If it does then you have likely popped the new sensor
    Paul
    Are there optical switches with a better voltage tolerance ?
    Am currently trying to set up a profile in Linux cnc .
    Would that be an easier to place to start .
    Quote Originally Posted by depronman View Post
    Paul
    Have tried that and the yellow light goes out so sounds like I am stuck until I get some resistors .
    Will look out for my mail early in the week.
    Had a look on RSwww and literally pence each but with £4.95 postage
    so at least you have proven the wiring is correct and the setup in Mach3 is also correct
    just need the resistors and fit a new pair of optical sensors and you should be good to go
    Paul
    That's interesting, I must have been given a business account (which has free postage for all orders) for some reason without realising it. I've been a customer for donkeys years and have never been charged postage.
    I think it depends where you live. In the UK postage is normally charged unless you order is over a certain amount at which point postage becomes free
    I have a deal through work where by I get free postage and on most thinks a little off the price
    I normally use CPC as they are local and if I need it quickly I can collect at their counter I find that I normally need something immediately so this works for me
    Paul
    I've just checked both the UK and Australian RS websites and you're right. Free delivery for all online orders for those of us living down under but not for you poor souls still living in pommieland.
  9. The Following User Says Thank You to Kitwn For This Useful Post:
  10. #9
    It’s a long way to come to Oz to get free delivery from RS . Sounds like a good excuse though...
    Paul
  11. #10
    Paul
    Any excuse is a good excuse for moving here, especially now.
  1. FOR SALE: Boxford TCL125 ATC
    By jonnydeen in forum Items For Sale
    Last Post: 27-11-2021, 12:41 AM
  2. FOR SALE: Boxford MT2 & Boxford TCL125
    Last Post: 12-11-2021, 11:24 AM
  3. WANTED: Automatic Tool Changer for Boxford TCL125
    By TomHennessy in forum Items Wanted
    Last Post: 31-10-2020, 10:25 AM
  4. FOR SALE: Boxford TCL125
    By 30tooo in forum Items For Sale
    Last Post: 28-06-2017, 04:29 PM
  5. BUILD LOG: fresh start 8x4 build
    By reefy86 in forum DIY Router Build Logs
    Last Post: 02-01-2017, 12:45 PM
