Thread: Boxford TCL125. (Fresh start )
10-11-2020 #1An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
The Following User Says Thank You to Kitwn For This Useful Post:
10-11-2020 #2
11-11-2020 #3
11-11-2020 #4
Another lesson this evening!
I decided to take a supply to the driver board from my 5 v PSU rather than regularly falling over a Usb lead from the computer.
And I took the opportunity to make some of the other wiring a bit more compact. So I had the power switched off , and unplugged for (I think) more than 20 mins when the 24 v supply cable touched the chassis giving me a hefty flash and lightly welding itself . Maybe need to be careful of big capacitors .
I think it has taken out the driver board as the traverses dont seem to be working.
Spindle controller still OK though .
Is there a way to quietly discharge the capacitor when I switch off??
11-11-2020 #5
11-11-2020 #6
Not as bad as initially assumed .. Board IS working but amazingly the jog function works better when some "plonker " does not forget to check that the "Jog on" function is selected Dooohhhhh!
Nonetheless I do feel it would be a good idea to bleed away charge from the capacitor when the the supply is broken . What size of resistor would be approprate ??
FOR SALE: Boxford TCL125 ATC
By jonnydeen in forum Items For SaleReplies: 4Last Post: 27-11-2021, 12:41 AM -
FOR SALE: Boxford MT2 & Boxford TCL125
By jonnydeen in forum Items For SaleReplies: 3Last Post: 12-11-2021, 11:24 AM -
WANTED: Automatic Tool Changer for Boxford TCL125
By TomHennessy in forum Items WantedReplies: 14Last Post: 31-10-2020, 10:25 AM -
By 30tooo in forum Items For SaleReplies: 17Last Post: 28-06-2017, 04:29 PM -
BUILD LOG: fresh start 8x4 build
By reefy86 in forum DIY Router Build LogsReplies: 31Last Post: 02-01-2017, 12:45 PM
. Sounds like a good excuse though...
