No. It won't harm the motor, it can run hot well in excess of 50C.
Ie. re the drive what voltage can it handle. if it is 50V then use about 10% less 45V. it is the volts that matter.
What voltage are you using and what amps can the power supply give?..Clive
04-01-2021 #2
This particular driver (linked below) connects directly to AC so it's 240vAC. It has the PSU built in unlike the DM 542T drivers I have which utilize a separate PSU that supplies 42.5 volts. I double checked and there is nowhere you can select the voltage, the manual suggests this is set automatically by the driver. Do let me know if I've done something stupid there.
https://www.omc-stepperonline.com/di...per-motor.html
In terms of Amps, this screen grab shows you all the different options.
04-01-2021 #3Just to be clear that you are using the 3 phase driver that is supplied by 230v ac. I so that is fine.This particular driver (linked below) connects directly to AC so it's 240vAC. It has the PSU built in unlike the DM 542T drivers I have which utilize a separate PSU that supplies 42.5 volts.
As a lot of steppers are two phase. I take it your stepper is actually 3 phase.
What controller are you using to drive it ?..Clive
04-01-2021 #4
Yes, it is a 3 phase stepper.
The controller is a piece of software called Mantis which is designed for motion control video - https://www.bfg-motion.com/index.php?p=1_4
04-01-2021 #5
Ok well, this convinces me even more that it's something wrong with the linear stage rather than the motor.
I fit these types of motors all the time, by type I mean 3 phase Motor with 220V mains powered drives and I can tell you without a doubt that at this size just reducing the current shouldn't make it stall on an unloaded linear stage that using ball-screws.! . . . Unless the stage as gots excessive friction from misalignment or something being bent.
This also fits with the noise because the power in these motors will easily overcome any friction, other than outright sticking, this would cause vibrations as it powers thru any sticktion.
For instance, a 7.5Nm Nema 34 motor with 220V drives connected to a ball-screw will easily lift a fully grown man off the ground and not bat an eyelid.
When working on a CNC machine it will happily accelerate a 50kg mass holding the spindle in excess of 2G to a velocity of 20mtr/min and bring it back to a dead stop in fractions of seconds and then push that same mass with a 12.5mm tool thru a solid piece of Oak at 8mtr/min.!!
So hopefully you're getting some idea of what I mean when I say an unloaded linear stage that uses a ball screw shouldn't be making it stall just because the current is set a little low.
I'm sticking with my first suggestion that the linear stage is binding or bent or twisted.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
How to align ball screw to linear rail?
By Sterob in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 23-04-2020, 10:59 PM -
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
eBay: THK KR33 Linear Actuator (Great for Z-Axis)
By biketrialsdave in forum Items On eBay UKReplies: 0Last Post: 21-01-2016, 03:17 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM
