    Hi guys, im looking to make a bunch of 3-4mm holes in aluminium (6061) but i understand drills are kind of out off the question due to the spindle speed being too high. so my question is how should this be done? I could buy some smaller 1-2mm endmills and machine them out but i feel this will just leave me with a bunch of snapped mills and end up costing a fortune, my router is running flood cooling if that helps at all and has a standard 2.2kw Chinese spindle on it.
    thanks in advance Oli
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by tankproof2 View Post
    That should be no problem the spindle will run fine a 7K revs use a stub drill or even a 2-3 flute end mill and peck drill it.
    4mm will be no problem, I drill 4.2mm (m5) holes all the time in aluminum with a 2.2Kw spindle, just use a peck drilling strategy. For the 3mm holes, I would start them first with a spot drill because a smaller drill can wander off.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. RFQ: Looking to make a small part (49*49*11mm) out of Brass or Aluminium
    By russmx in forum Projects, Jobs & Requests
    Last Post: 11-07-2020, 03:25 PM
  2. Replies: 0
    Last Post: 15-07-2019, 01:17 PM
  3. Replies: 0
    Last Post: 07-05-2018, 07:18 PM
  4. Drilling Ø0.2mm holes on aluminium
    By hoezap in forum Metalwork Discussion
    Last Post: 09-04-2016, 06:28 PM
  5. RFQ: Someone to make a small punch die
    By Steve Robinson in forum Projects, Jobs & Requests
    Last Post: 08-03-2016, 09:40 PM
