Thread: Advice Required
26-04-2021 #1
Hi guys, I am trying (without much luck so far) to source a new spindle for my RF45 mill. It was in a bygone day branded as a Chester Lux. I got it about 10 years ago and converted it to cnc. About two years ago I also converted it from a geared drive to just a belt drive so as I could get more rpm (up to 3000rpm). I have always had a soft knocking noise from the spindle, so while on lockdown I decided to take it apart and renew the bearings. Whilst it was stripped down I noticed that the bearings weren't quite what I would call a "bearing fit" on the spindle, eg they could be pulled on and off just by finger pressure. I can only assume that this could be causing the noise I am hearing. The splines on the top of the spindle are also slightly worn.
So, I am trying to find another spindle, but can't seem to find anything. I am waiting on Chester Machinetools getting back to me as I type this, but am wondering if I have any other options. Is there such a thing as a motor/spindle combined where I could just remove the whole head, and fabricate a mounting for such a thing. Ideally I would like to increase the spindle speed even more (5000/7000rpm, but not to the point of fitting a chinese water cooled job as I think the neighbours would be complaining too much.
If anyone has a spare spindle with an MT3 end, that they no longer need, or if anyone can suggest an alternative I'd be happy to hear from them.
MicroRouter Spindle upgrade - advice and help required
By ngwagwa in forum Spindles & Drive MotorsReplies: 16Last Post: 26-05-2019, 02:52 PM -
DIY 6040 CNC - advice required!
By Pointy in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 14-09-2016, 12:05 PM -
NEW MEMBER: Milling work required would appreciate some help and advice - New member
By reidy- in forum New Member IntroductionsReplies: 2Last Post: 04-05-2015, 10:21 AM -
advice on software and machine required please.
By iamspuddy in forum CAD & CAM SoftwareReplies: 9Last Post: 18-04-2012, 08:14 PM -
NEW MEMBER: Hello everyone advice required please.
By Paul-in-Bury in forum New Member IntroductionsReplies: 1Last Post: 26-01-2012, 11:57 PM
