Thread: Cheap Idea for a DRO
11-05-2010 #11
i reckon the combs should be easy to mill out on a CNC PCB mill. They are 0.6mm thick PCB double sided but the reverse is plain. On the top side is the T-comb structure and a ground strip. Since the mechnaism is a capacitive vernier it would seem perectly reasonable to manufacture this in say 150 or 200mm approx lengths where the end is exacly halfway through a 'T' and then end butt them together ensuring electrical conductivity across the join with a solder infil. getting positional accuracy on the second or subsequent 'comb' is the critical factor (as well as the basic accuracy of the comb). Some sort of jig might do the job.
Alternately, buy 3 cheap ones and look to join the PCB together as per above. Milling a new channel from stainless might be tricky, but aluminium might do just as well.
It worth an experiment don't you think?
Website idea.
By qwertyjon in forum General ComputingReplies: 8Last Post: 05-04-2014, 03:29 PM -
Here's an idea hacking a Kress 1050 FME
By m.marino in forum Kress Milling MotorsReplies: 3Last Post: 16-01-2013, 01:05 AM -
Why they don't want to accept my idea?
By hoezap in forum Tool & Tooling TechnologyReplies: 5Last Post: 14-07-2012, 01:15 AM -
business idea?
By homer93 in forum Marketplace DiscussionReplies: 7Last Post: 01-06-2012, 12:56 PM -
BUILD LOG: Mel's Odd Idea
By mel_earp in forum DIY Router Build LogsReplies: 3Last Post: 19-03-2010, 11:54 AM
