Thread: UCCNC shuts down unexpectedly
I am using V1.12111 but as you will have sen above, Andy's pointing me to Event Viewer in W10 has thrown up some evidence. As a simple first option I'm gong to try re-loading UCCNC itself (after ensuring the configuration is saved!) in case there's been a corruption of the .dll file mentioned in the error report. If the problem shows up again at least I know where to find the error log which I can send to Balazs if necessary.
EDIT:
Having done some research on the ntdll.dll file blamed for the problem, this turns out to be a Windows issue as suggested. This little file has been part of every version of Windows since NT (hence the name) and it's corruption is a know cause of crashes of all sorts.
Thanks to everybody for the help.
KitLast edited by Kitwn; 16-07-2021 at 05:08 AM.
16-07-2021 #2
Hi Kit,
Unfortunately the ntdll.dll error is quite a common one, but common because it can have a wide array of causes. It's basically the Windows kernel is freaking out and killing UCCNC. The status code it's given (0xc000374) is telling us that the reason is memory heap corruption - i.e. UCCNC is trying to use a bit of memory that it thinks should belong to it but Windows thinks otherwise. If you can copy paste / screenshot more of the details that screen shows it might be helpful, also slightly worryingly you have a lot of other warnings there which could give some clues.
This can be caused by a new update introducing a bug, a new bit of software that is being evil and corrupting the memory, a bad device driver (or a device misbehaving), or the PCs RAM is starting to fail.
I would try the following in this order:
Swap out the RAM for fresh / alternative sticks if you have them handy. If not, but slightly less conclusive, run a memory test tool like memtest86
See if disabling that plugin helps, could be the Xbox controller device / driver is faulting.
Swap to another ethernet card if possible to rule out the ethernet driver or NIC dying.
Try the windows SFC repair tool - long shot but if it works then easier than reinstalling everything.
Fresh reinstall of Windows, preferably on a new SSD (they're a lot cheaper than they were!)
Hope we get to the bottom of it soon...
The Following User Says Thank You to AndyUK For This Useful Post:
Uccnc and rasbery pi
By valdis034 in forum General DiscussionReplies: 2Last Post: 12-11-2020, 05:26 PM -
UCCNC intrusive pendant
By John11668 in forum General DiscussionReplies: 2Last Post: 29-07-2020, 10:39 AM -
UCCNC with UB1 Sanity Check
By iforeman in forum CNCdrive (UCCNC)Replies: 6Last Post: 23-06-2020, 06:42 PM -
Uccnc software question
By jtar40 in forum General ElectronicsReplies: 2Last Post: 11-11-2018, 12:44 AM -
UCCNC MyProbe error
By chipxx in forum CNCdrive (UCCNC)Replies: 0Last Post: 22-08-2017, 02:36 PM
