I can see the attraction of the AXBB-E for 4 axis systems with modest I/O, plus the inclusion of analogue outputs to control the VFD speed. It even has a jumper to allow either 5V or 10V range for the speed. I think for the majority of hobby users it would be a perfect little unit.
But I need 5 stepper motor control, so the extra space for the additional board just to driver the 5th axis makes it similar to the UC300ETH+UCBB in terms of footprint. More thinking . . . .
29-08-2021 #2
Well. I have mine stacked. I have uprights through the UCBB mount holes (3mm threaded rods + 4mm od brass tubes) going up to 2 ally straps. The UC300 is then fitted on top.
I can still get to all the screw terminals of the UCBB. Looks a little bodged on mine but it saved a lot of space.
New UC300ETH Breakout Board/Motherboard
By Ger21 in forum CNCdrive (UC100, UC300ETH)Replies: 10Last Post: 17-07-2019, 09:41 PM -
anyone using an e-cut 1 mhz usb breakout board
By nobby in forum Control Hardware & SystemsReplies: 10Last Post: 22-10-2018, 11:50 PM -
which breakout board?
By johngoodrich in forum General ElectronicsReplies: 4Last Post: 12-03-2017, 01:54 AM -
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
