That relay will short out the inrush limiting resistor once the big DC bus caps have been charged and the internal PSU comes up. As m_c says, it's more likely to be a symptom rather than the cause. If you manage to replace the green resistor, I'm pretty certain you will simply roast it again.
I think the question is whether you replace the HY inverter with a similar one or spend a bit more for an industrial drive - Jazz is recommending a new HY one.
14-10-2021 #2
No, I'm not.!! . . . Where did I say that.?
I just said the ones we fit now are very reliable which is the truth, I've probably had 2 or 3 go faulty in 6yrs, that last one being near 5yrs old and used every day in a commercial woodshop which isn't bad going for supposedly Cheap drive . . . I've also had an ABB go down in that time as well so buying industrial or quality isn't always a guarantee of reliability..
Email: [email protected]
Web site: www.jazzcnc.co.uk
HELP no power on my VFD HY02D223B
By alex wight in forum Generic Chinese SpindlesReplies: 3Last Post: 13-07-2021, 05:01 PM -
Wiring Potentiometer on HY02D223B
By Lodds in forum Workshop & EquipmentReplies: 0Last Post: 30-09-2020, 05:54 PM -
Huanyang HY02D223B VFD Question
By iforeman in forum General DiscussionReplies: 2Last Post: 26-10-2017, 05:00 PM -
Wiring Huanyang HY02D223B
By Stan in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2017, 07:25 AM -
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM
