Thread: New Member
At the end of the day you say you want something that will do aluminium and wood.
It will need to be fairly rigid and have some decent drive.
If you try and do it really low budget, try to fudge controls and are willing to cut corners. Then I suggest you abandon it.
It's a far cry away from a £50 3d printer kit.
I'm surprised the steppers moves at all with 3:1 (big pulley stepper > little pulley screw) yes?.
You don't even need that inless you're trying to achieve a possible 15,000mm/min top speed (15m)! (that's based on 5mm screw)
Most machines I see this size are direct driven (no belts) or 2:1. The long base driven by 2 steppers 1+slave.
Direct drive with a stepper of max 1000rpm driven direct gives max 5000mm/min with 5mm pitch screw..
If you want more speed you either get 10mm pitch screws or just buy AC servos with 3000rpm (NOT hybrid stepper type).
I suggest you do more research, look at more images etc and go from there.
I mean to buy a basic Workbee (crap) which aren't great with cutting alum, are £1500 start WITHOUT even a router head.
18-11-2021 #2
Mainly wood with a bit of aluminium but yes, I get your point
hmm, maybe a misunderstanding.If you try and do it really low budget, try to fudge controls and are willing to cut corners. Then I suggest you abandon it.
I'm willing to fudge and cut corners to test if something works, if it does then I do it properly :)
no mate, the other way around, little pulley on stepper -> big pulley on shaft, little pulley on other end onto the drive belt. so the stepper will turn 3 times to make the belt pulley turn once.I'm surprised the steppers moves at all with 3:1 (big pulley stepper > little pulley screw) yes?.
But as mentioned above, I've already decided to drop that in favour of dual lead screws
that's where I'm headngMost machines I see this size are direct driven (no belts) or 2:1. The long base driven by 2 steppers 1+slave.
I fully accept I'm doing this with no experience but it's getting there, slowly, and i'm learning and having fun. Hopefully I'll end up with something that does what I want but either way, I'll enjoy the journey :)
Thanks for your inputMy YouTube channel
There are 3 types of people, those who can count and those who can't.
