Thread: Re-Building Suregrave CNC
20-01-2022 #10
Word of caution with using 48V with drives rated at 50V, esp the DM542 clones which don't tolerate over-voltage well.
Steppers generate electricity when de-accelerating and will send this back to the drives and PSU so with drives rated at 50V Max and 48V PSU the back EMF can easily exceed and damage the drives.
Also with 48V if your incoming AC electricity fluctuates like most domestic supplies do then you can easily exceed the drive's Max rating as the Output is relative to the Input voltage unless regulated and damage them or at best shorten their life.
Another issue with back EMF is that if your PSU's are the regulated type, which the video doesn't show so can't tell, the back EMF can cause them to shut down to protect themselves which is the last thing you need on a CNC machine so regulated PSU is not recommended. The best type of PSU is an Unregulated one and the best type for CNC is a toroidal supply as it absorbs back-EMF much better.
When sizing PSU you really need to leave a 10% safety margin and with 48V you are too close for comfort so I would advise you to keep the speeds and acceleration down.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
WANTED: Dahlgren dsc2000 black box to drive Gryphon suregrave router
By relayman in forum Items WantedReplies: 13Last Post: 08-12-2023, 11:09 AM -
Rebuilding gantry type Suregrave engraver - advice needed!
By GordonB in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 14-06-2020, 04:52 AM -
Suregrave Excalibur DT (2516i) with DSC2000
By DiGi5670 in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 16-08-2017, 11:28 PM -
FOR SALE: SUREGRAVE 2516I cnc/ router
By Lesley ungi in forum Items For SaleReplies: 1Last Post: 15-07-2017, 08:56 PM -
Suregrave cnc router
By terry1956 in forum Machine DiscussionReplies: 13Last Post: 24-05-2017, 03:19 PM
