    Hi Muzzer
    Any chance of a quick schematic for timer relay and a metal clad resistor wiring ?
    Thanks in advance.
    Andrew
    Quote Originally Posted by the great waldo View Post
    Hi Muzzer
    Thanks in advance.
    Andrew
    I'm not Muzzer but as I understand it, just wire the resistor across the terminals of the timer on the input side ie in parallel. When the timer relay is open the current flows through the resistor, expending inrush current as heat. Then after a short period the timer relay closes, the current will choose the path of least resistance and flow through your main circuit instead. Just have to make sure your resistor is appropriately sized.
    It's actually the same thing as my module just using commercial units.
  1. Soft limits over ride
    By Pilsbury in forum Machine Discussion
    Last Post: 01-12-2022, 01:36 PM
  2. Is there a 'standard' base design, or does everyone start from scratch?
    By Richard in forum Gantry/Router Machines & Building
    Last Post: 27-10-2017, 09:13 AM
  3. Soft Start Advice
    By GTJim in forum General Electronics
    Last Post: 15-01-2015, 08:47 AM
  4. RFQ: Panels cut from soft plywood
    By Rockeyes in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 04:38 AM
  5. Simple Current Limiter (LM317)
    By Mad Professor in forum General Electronics
    Last Post: 13-07-2009, 10:01 PM
