    I prefer uncoated carbide with honed or "lapped" edges (= razer sharp!) and the only issue I've had has been when using high material removal rates rates - failure to clear the swarf can result in chips being dragged back into the cutting zone ("recutting"). This usually ends with the chips becoming welded to the tool, with a breakage following quickly afterwards. If you supply enough coolant and/or air to clear the chips, the material removal rate and surface finish are impressive.
    I like the YG-1 Alu Power cutters https://www.cutwel.co.uk/milling-too...e51-yg-1-e5e51 and tend to buy them when they are on offer (buy 2 get one free etc) but there are similar ones available from Ali Express if you look carefully eg https://www.yuzemachinery.com/.
    Many coated cutters actually stick to aluminium, so it's good to avoid them. And the cutting angles are different for aluminium and steel.
    Here - have a laugh at this. Shows what happens when you fail to clear the chips (working into a corner like this was asking for recutting). I wouldn't attempt this now without using coolant and air.
    And again:
    Chaz's Avatar
    And again:
    Nice cutting on what looks to be slowish Speed (due to machine). Whats your DOC and Feed Rate please?
  1. 6&8mm Downcut 2 flute carbide end mills
    By Leadhead in forum Tool & Tooling Technology
    Last Post: 13-10-2019, 10:34 AM
  2. FOR SALE: Teeny carbide end mills and burrs
    By evildrome in forum Items For Sale
    Last Post: 05-05-2018, 10:20 PM
  3. FOR SALE: ITC 3051 10mm 3 Flute Long Length Carbide Ali End Mills
    By Caster1 in forum Items For Sale
    Last Post: 05-01-2016, 12:21 AM
  4. Carbide End Mills now available from shop-apt.co.uk
    By APT in forum Manufacturer News
    Last Post: 07-03-2012, 10:23 PM
  5. FOR SALE: Mills, Thread Mill, Carbide Drills...
    Last Post: 21-03-2011, 01:47 PM
