    Hi All.
    Is there a forum member willing to proof and amend where necessary, my control schematic for my self built CNC wood router?
    Regards.
    Ray
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Just post up what you have, and we'll advise/recommend
    Hi.
    This schematic was made in MD PowerPoint then converted to PDF, I hope it is ok, i do not have a drawing package.
    Regards
    Ray
    Attached Files Attached Files
    Here's another.
    Quick look over.
    Pg1/2
    What spindle are you using? This will change what advise would be best.
    Earth shouldn't go through the isolator (probably just the way things have been drawn, but earths should never be switched)
    You'd need quite a beefy E-stop to handle switching mains voltage directly at the currents involved
    Pg3
    Those fuses/Circuit breakers should not be there. There should be no switching/fuses of any kind between the stepper drivers and the motors
    Pg4
    All good.
    (note - Power to the steppers should come individually from the power supply as per the diagram, and not daisy chained along the drivers)
    Pg5
    You'll need to make sure that arduino outputs are capable of power the drivers inputs.
    Other than current limitation of the Arduino outputs, there is no need to have all the enables on separate outputs.
    Note - I'd have to check the DM manual, but the drivers may default to enabled anyway i.e. be enabled without any power applied to the enable input, and disabled when power is applied to the enables.
    Hi, Thanks for taking the time to view my circuit.
    I have a choice of routers, one is 240 vac 710 Watt, the other is 240 vac 1200 Watt, not yet sure which to go with.
    Regards and Thank You.
    Ray.
    Hi m_c.
    I have removed the Trips from Page 3. I ham now struggling as to where I place the E Stop in the circuit, do I need to cut the power supply to the stepper drivers, the stepper motors and the UNO??
    Regards.
    Ray
    Hi m_c.
    Will this work?
    RayCNC electrics Master - Copy.pdf
    Quote Originally Posted by The Gresley Luthier View Post
    Hi m_c.
    Will this work?
    Looks like you've removed the fuse from the spindle AC input, and there is no separate fuse to the 24V PSU?
    This means that the fuse in your mains plug is now covering both devices... Which means they wouldn't trip as fast as they should. Imagine if your PSU had a fault, instead of a ~4A fuse it now has a 13A fuse...
    Order should be: Mains -> Plug -> Fuse in Plug -> On Off Switch -> EStop (I have my reservations about this but you seem to want to do it without a safety relay...) -> Mains Distribution -> Individual Device Fuses -> Individual Devices.
    Why are you using an Arduino UNO rather than a dedicated CNC controller? If it's a cost thing, I bought a MKS DLC32 from AliExpress then other day for £15 delivered.... It runs FluidNC beautifully, and I can guarantee it'll outperform that Uno. It has dedicated motor drive outputs for 4 or 5 axis, a spindle control circuit, an Estop circuit, probe and limit switch pinouts... Oh and onboard Bluetooth and WiFi, with a web server for on the fly config and control. The 3D printer revolution has made lots of cheaper end items available.
    Thanks Andy.
    I think I understand what you are saying,
    I am open to use any control system that is recommended to me, the reason I initially chose Arduino is that I am familiar with Arduino IDE writing, also I have several Arduino Uno's in my collection of spares, I can afford another £20.00 if it's worthwhile.
    Did you read my schematic right, the drawing shows the SSR input as vdc, the output shows vac.
    You seem to know what I am trying to achieve, as stated earlier, I am a Mechanic not an Electrician, can you guide me by supplying a schematic??
    Regards.
    Ray
  1. Sound proofing
    By CharlieRam in forum Workshop & Equipment
    Last Post: 15-06-2021, 10:45 PM
  2. NEE AMC-E schematic or suggested alternative control boards
    By DaveBee in forum General Electronics
    Last Post: 05-03-2019, 04:31 PM
  3. New Control Box with DDCSV - Help needed
    By Rye in forum Chinese Stand-alone
    Last Post: 14-04-2018, 10:50 PM
  4. Control Schematic Advice
    By GTJim in forum General Electronics
    Last Post: 05-10-2015, 11:48 AM
  5. router sound proofing
    By universally in forum General Discussion
    Last Post: 02-10-2015, 05:30 PM
