    Here's some info on the motors setupin Mach3...need any more please let me know?
    I'm summising in the diagnostics screen those red lights should be green? but no matter what I do I cannot get them to turn green?
ID:	2403   Click image for larger version.
ID:	2404   Click image for larger version.
ID:	2405   Click image for larger version.
  2. Quote Originally Posted by GeorgeD View Post
    George,
    In the Outputs tab, disable the 'enable #1,#2,#3 and output #1,#2,#3 lines (red X them) but enable the ChargePump line on pin 1... I suspect thats the reason its not singing... assuming wiring is OK
  1. BUILD LOG: 1250 x 1250 cnc router (from scratch)
    By Danielroyal25 in forum DIY Router Build Logs
    Last Post: 08-08-2014, 07:35 PM
  2. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 10-01-2014, 12:53 AM
  3. NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
    By AGB in forum New Member Introductions
    Last Post: 06-02-2013, 03:16 AM
  4. Starting from scratch, what would you use as a base for a CNC metal lathe?
    By m_c in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 23-01-2011, 05:37 PM
  5. Building from Scratch or follow some plans?
    By Monk in forum Gantry/Router Machines & Building
    Last Post: 12-08-2010, 10:27 PM
