Hi Johnathan
personally I wouldn't go for that length of travel on unsupported rail. The calculation you need is for a cantilevered beam, just you have it mounted vertically. As a rule of thumb I look at third points, so for a cantilever of 400mm you would need a 1200mm rail with the mounts 800mm apart. (not very feasible)
If this is a router then I guess this will then be mounted on a y axis gantry and needs moving as well so overall weight will be an issue. Is there a reason you need such a long z or could you just change the bed height
21-08-2010 #2
600mm is about as much as is practical allready. I read somewhere a rule of 2:1, i.e. if the bearings are 200mm apart then it's acceptable to have the force (of the cutter) 400mm away.
Yes it's a gantry router. I can think of things I'd like to make which need that long a Z, maybe not quite 400mm but close enough.
With regards to accelerating the mass of big Z axis/gantry I should be ok as on the X-axis I'm using two 3Nm steppers @ 70V for the and spinning the nuts, not the screws. The nut is currently held between two tapered roller bearings with a pulley in between.
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
