    ecat's Avatar
    Location unknown. Last Activity: 08-02-2014 Has been a member for 9-10 years. Has a total post count of 157. Received thanks 5 times, giving thanks to others 8 times.
    Minimum order £100, easy :) I just looked at the cost of the Y cross beam, say 40x200x700, sobering at about £70. Still, in this CNC game everything appears to work out at about £50 to £100 per part :confused:
    Time to do the pros and cons calcs..
    Cost:
    Plate: 700x200x20, something like Steve's, £50
    Profile: as above £70.
    Weight:
    Plate: 7.6kg
    Profile: 4.8kg
    N.B.
    While not total mince, my inability to read all the instructions on botlanta web page resulted in deflection calcs that do not compare like for like, see post 15 for corrections.
    Deflection due to 200N vertical force:
    Plate: 0.02mm (http://www.botlanta.org/converters/d...c/bending.html, got to love imperial measurements, hope my conversions were correct)
    Profile: less than 0.00mm for 40x160 (Bosh profile deflection calc)
    Deflection due to 70N horizontal force:
    Plate: 0.82mm
    Profile: 0.01mm, again for Bosch 40x160
    Disclaimer: the above values are from my calcs and sources I've found, they may be total pants!
    In this case I think profile wins. k, back to the calcs...
  2. The Following User Says Thank You to ecat For This Useful Post:
  3. #2
    Quote Originally Posted by ecat View Post
    Just to throw another spanner in the works, I'm planning on using square tube for best stiffness / cost ratio...
    http://www.aluminiumwarehouse.co.uk/...duct_info.html
    Not as convenient as profile but it should be possible to join quite accurately with a bit of drilling and tapping and a lot cheaper.
    Plate: 0.82mm
    nice one ecat... your calcs seem to good to be true... fingers crossed
    the valuframe 200x40 is much more dense than the Bosch so should perform better
    great price... would need some special fitting cosideratons to get the most out of its stiffness... internal spacers etc... making good stiff corners would take a bit of head scratching
  5. #4
    ecat's Avatar
    Quote Originally Posted by FatFreddie View Post
    http://www.aluminiumwarehouse.co.uk/Aluminium-Square_Tube/c120_129/p29830/Aluminium_Square_Tube_(6082T6)_3_in_x_3_in_x_1/4_in/product_info.html
    Oo, nice link. I collect them
    Too good indeed... I should check them again. Meanwhile, A quick sanity check...
    The formula is: Deflection =W*L^ 3/ 3*E*I
    Where W is force, L is length, E is Modulas of Elasticity in psi, and I is Second Moment of Inertia.
    Moment of inertia is calculated by (width * thickness^3) / 12
    So I varies with the cube of thickness.
    Looking at the horizontal force the plate is 20mm thick, the profile is 40mm thick. 40^3 / 20^3 = 8. Whoops, my calcs are 10 times that...
    A-ha, the Beam calc web page is for beams supported at only 1 end, the profile figure is for a beam supported at both ends. Note to self, just because the link comes from a CNC site it doesn't mean the linked page is what you think it is!
    There is a spread sheet around here somewhere, I'll get back to you...
  6. #5
    There are two here, one from Ross (#1) and one from me (#3). Mine includes the torsion calc (due to the cutting force being offset in Z from the gantry, trying to twist the gantry). You might want to consider that on top of the vertical and horizontal forces mentioned above.
    http://www.mycncuk.com/forums/showth...ail-Calculator
    As for cutting ali with simple tools, you can cut profile with a mitre saw with a metal cutting blade, so should be able to cut plate. Mine was a Rexon ~£100, but there are cheaper ones. Blade was a branded part at £44 - you can get cheaper but I didn't want it to let go and do me some damage.
  1. push down plate,
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 31-07-2013, 11:38 PM
  2. EXPERIENCE: Z Plate made by DOM
    By dudz in forum Trading Experience & Feedback
    Last Post: 28-11-2012, 08:12 PM
  3. what is aluminium plate
    By martin54 in forum General Discussion
    Last Post: 11-10-2012, 01:44 AM
  4. RFQ: Mounting Plate
    By ferus in forum Projects, Jobs & Requests
    Last Post: 26-10-2011, 02:56 AM
  5. eBay: 2GB USB Flash Memory, Swivel Stick (black)
    By Lee Roberts in forum Items On eBay UK
    Last Post: 17-12-2008, 05:34 PM
