23-08-2010 #30
I started off down that path of calculating the I values of each bit in Autocad and the parallel axis etc...... but gave up on the torsion constant for irregular shapes, when I was looking on the net I kept seeing reference to to the 2 polar moment which CAD can also work out but this is only true for circular tube and bar. I only gave up because I can now use FEA to do it all for me. if you get any where then I sure would like to know.
I also found that the more you analise it the more time it takes and you soon realise that, as Barry pointed out, just doing a few basic cals on the main structure will be sufficient. adding the rails etc becomes the factor of safety that seems to be missing from a lot of calcs. :naughty:Last edited by Ross77; 23-08-2010 at 10:44 PM.
Z axis assembly - unsupported rail for very limited movement
By dsc in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 10-10-2012, 12:44 PM -
round, supported or profiled rail?
By mocha in forum Rails, Guideways & BearingsReplies: 0Last Post: 26-07-2012, 03:44 PM -
WANTED: 2 x 20/16mm supported round rail
By D-man in forum Items WantedReplies: 4Last Post: 30-10-2011, 11:08 PM -
Profile v Supported Round Rail
By Rogue in forum Rails, Guideways & BearingsReplies: 5Last Post: 15-09-2011, 09:29 PM -
FOR SALE: Round linear rail and bearings
By routercnc in forum Items For SaleReplies: 5Last Post: 19-08-2010, 05:17 PM
