    Or you could mount the stepper on a sliding arrangement so that rotations were prevented but it could slide back and forth 0.5mm or so.
    Maybe put a rubber O-ring on each of the 4 bolts that mount the stepper motor. I did that on my rotary table to compensate for a little radial misalignment and it works fine.
    It could also damp vibrations...
    Oldham couplings were designed to take out radial misalignment, Those lovejoy couplings are a total waste of time and space for CNC machines, they are better off driving sewerage pumps.
    John S -
    Oldham couplings were designed to take out radial misalignment...
    Yes I know...didn't have time to make an Oldham coupling at the time for the rotary table and haven't bothered since because it works fine. It's only a very very slight misalignment.
  1. Plasma floating head...
    Last Post: 01-01-2015, 01:52 PM
  2. Driving me insane
    By Bush Flyer in forum Motor Drivers & Controllers
    Last Post: 14-04-2014, 03:55 PM
  3. ballnut housing and floating end ballscrew assembly
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 12-07-2013, 08:22 AM
  4. non-locating / floating bearing - shaft location
    By dsc in forum Linear & Rotary Motion
    Last Post: 28-06-2013, 10:07 PM
  5. Driving 2 steppers from one driver?
    By Dan Brown in forum Stepper & Servo Motors
    Last Post: 20-12-2009, 07:26 PM
