Thread: ER11 Collet size lying?
Use decent quality collets and chuck, make sure they're clean and located in the nut properly, and you shouldn't have any problems. Only time I've had problems is when I've tried to cut corners while swapping tools, and got a bit dirt in or not located them in the nut properly.
14-04-2011 #2
True, I wasn't giving the whole story. Also if you look at the recommended torque for the collect nut it's surprisingly large. Probably quite easy to obtain the 28Nm required for ER11. Big spanner needed for the bigger collets though - apparently it's about 105Nm for ER25 which I have on my mill.
Clamping nut - ER11 collet... am I being thick?...
By Doddy in forum Tool & Tooling TechnologyReplies: 2Last Post: 31-01-2014, 07:05 PM -
WANTED: Wanted - a 1/4" (6.35mm) ER11 collet.
By HankMcSpank in forum Items WantedReplies: 4Last Post: 17-09-2013, 07:45 PM -
FOR SALE: For Sale, Chinese 1.5kw spindle (er11 collet) with matching VFD! with 4 & 6mm collet
By jcb121 in forum Items For SaleReplies: 1Last Post: 29-01-2013, 11:05 AM -
What does ER stand for in "ER11 collet"?
By bruin in forum Tool & Tooling TechnologyReplies: 4Last Post: 06-09-2012, 01:36 PM -
CNC 3040 Collet size and other questions?
By Musht in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 15-02-2012, 02:26 AM
