12-01-2009 #2
Supported for X and Y is preferable because the weight of the load (router + vertical forces) causes significant negative deflection in the vertical plane which the support effectively resists. However supported rail is strong to resist loads into the support but poor when being pulled away from the support which is why Gary recommends something stronger such solid profiled rails where the glides run on the edge and better resist forces equally into and out of the plane of the rail as well as turning moments.
Thats doesnt mean you cant use unsupported rail in thr Z direction. In reality the deflection will be much smaller than what I suggested and for a small machine 12 or 16mm rail may well be adequate if the depth of cut is kept small enough. As Lee says, his works fine...
12-01-2009 #3
Yes this is why.
I have had customers use supported (TBR) rail for Z, and it worked, but i dont suggest it.
If the Z is a short stroke, standard 16mm should be sufficient, for light wood and plastic, or 20mm if you can stretch to it.
I dont suggest using 12, 13 or 16 mm rail for X and Y, unless doing very light work or engraving.
Visit Us: www.automationshop.co.uk
FOR SALE: 16mm round rail, bearings and clamps - 300mm long
By Tenson in forum Items For SaleReplies: 0Last Post: 25-01-2014, 12:43 AM -
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
WANTED: 2 x 20/16mm supported round rail
By D-man in forum Items WantedReplies: 4Last Post: 30-10-2011, 11:08 PM -
FOR SALE: Round linear rail and bearings
By routercnc in forum Items For SaleReplies: 5Last Post: 19-08-2010, 05:17 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
