Page 1 of 6 123 ... LastLast
    Assuming there are no clearance issues with the table/nut, are there any disadvantages to mounting the motor under the table, parallel to the leadscrew?
    Another of my soon-to-be-infamous-for-low-quality example images:
    (not sure if the picture worked, ISP is being a pain today)
    I'm hoping that a pulley system of some form would be suitable to belt-drive the leadscrew from that location.
    IMO I dont see any problems with mounting as drawn as long as the spindle protudes enough for a pully, and I think it keeps things tidy.
    Jim
  3. The Following User Says Thank You to GTJim For This Useful Post:
    Quote Originally Posted by GTJim View Post
    Jim
    here! here!
    and if you think your drawings are basic i do all mine in paint!!! so you will never win that competition.....
  5. #4
    You could mill a pocket in the shaft side of the aluminium to accommodate the pulley if there is not enough space.
    Pulleys are definitely good plan as they will let you change the ratio allowing the stepper motor to be put in the right region of the speed/torque curve. You can also swap them round to get more resolution if required.
  6. The Following User Says Thank You to Jonathan For This Useful Post:
  7. This is similar to what i did with my first machine.
    http://www.mycncuk.com/forums/attach...2&d=1269125465
    Plenty of pics on my build
    http://www.mycncuk.com/forums/showth...tempt-Of-A-CNC
  8. #6
    Sorry for the delay in replying. Had ISP issues for a few days and my posts seem to intermittently require moderator approval (though I think it's when the post includes links).
    Jonathan: I think I'll be looking at some kind of pocket, but I still haven't started to research the pulley systems yet so I don't know what I will need in terms of size and clearance.
    AdCNC: Awesome build. This axis isn't fixed to the main structure though, it will be the X axis unit mounted on the Y axis.
  9. #7
    Quote Originally Posted by Rogue View Post
    I used XL pulleys , but HTD 5mm pitch is better. I've found 1/2" wide best to be fine. It's best to use reasonably big pulleys to reduce belt wear. In general minimum 5 teeth engaged with belt.
    ADCNC: like the setup with the coolant etc...
  10. #8
    Just to prove how slowly my brain works... by 1/2 wide do you mean I need to accomodate a diameter of 1/2", or it will protrude 1/2"(+bit sticking out for setscrew) from the mount?
  11. #9
    I meant the width of the timing belt should be at least 1/2". You can calculate it ... but that works fine for me so etc.
    I would want the shaft to stick out as far as you can get it to as it depends on the pulley, where the setscrews are and the position of the other pulley.
  12. #10
    Fair enough, so until I settle on a firm number I'll pencil in 1 1/2" clearance from the surface of the mounting block for the pulleys. I suppose judiciously placed idlers would also help with increasing the engagement with the belt.
    Is belt something that can be shortened easily, or will I be confined to designing around what is available?
  1. single and 3 phase motor sizing and mounting ?
    By Musht in forum General Electronics
    Last Post: 27-10-2013, 09:58 PM
  2. Dilemma with ball screw and motor mounting
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 12-08-2011, 10:58 AM
  3. Mounting a chuck on a Rotary table
    Last Post: 02-09-2010, 07:23 PM
  4. FOR SALE: Isel-automation Flat bed X-Y table with motors and mounting plate
    By Vespa Mad in forum Items For Sale
    Last Post: 27-08-2009, 08:45 AM
  5. 2 ways of mounting motor
    By Steve-m in forum Gantry/Router Machines & Building
    Last Post: 28-02-2009, 01:12 AM
