09-09-2011 #2
09-09-2011 #3
no it's not for a truss rod - it's for wires (LED fret markers).
Agreed, it's an onerous task, but believe me, I'd sh*t myself more by way of heating the fretboard with steam, prizing it off with lever, routing some wire channels, sanding the glue off the fretboard and neck, and then putting it all back together and then aligning it back up - ie aka this guy's way...
http://acapella.harmony-central.com/...-inlay-project.
....drilling a hole down the neck is the way to go!
I've knocked up a small 12 led (10 channel) led chaser & want to fit some LEDs in the fretmarkers of my cheap guitar as an experiment.
09-09-2011 #4
WHAT???? you mean no cake???? downer!!!.....
it makes some sense now.... id be tempted to explore the posibility of drilling side on under the frettboard to the truss rod cavity
and pray there is enough room in there for your wires
can you still get the truss rod out ?
09-09-2011 #5
09-09-2011 #6
I'd guess the question relates to making use of what is already there - there might be a way of using the existing hole and extending it enough to fit the wires?
I have this mental image now of trying to thread a wiresaw down the truss hole in order to cut a small v-notch for the wires, and I'm breaking a sweat just thinking of all the horrible ways that could go wrong :confused:
09-09-2011 #7
Errrrm? i may be missunderstanding what you are trying to do.... i was assuming you where looking for a way to run your wiring from your fret inlayed LED lights to your guitar body and im thinking you already have a cavity in the neck running its full length directly under you fret inlays except for your 12th fret, im also assuming that the cavity is a U shape because of the way its manufactured and just maybe ther is enough room to run your wiring alongside the tension rod
09-09-2011 #8
You're understanding my final goal ....but I didn't understand your question about me having access to the truss rod (which suggested I already had my guitar here in pieces) ....I was talking in general - obviously there's a truss rod in every guitar neck, but not being a truss rod expert (or neck expert), I have no idea how much space there is between the top of it (assuming the guitar is lying on its back) & the fretboard rear 'face'.
Does anyone know if there's typically a 'void' there already? (ie a gap between the truss rod & the fretboard)...these would be thin wires, though quite a few of them - about 11 wires in fact)
Brians Pick and Place Project
By briand in forum Pick & Place MachinesReplies: 4Last Post: 08-02-2014, 04:45 PM -
NEW MEMBER: Hello! Another new guy wishing to pick brains and ask for opinions...
By seashaw in forum New Member IntroductionsReplies: 4Last Post: 17-10-2013, 11:01 AM -
JuKu's pick and place project
By JuKu in forum Pick & Place MachinesReplies: 3Last Post: 09-12-2012, 08:42 PM -
Pick and place log
By Robin Hewitt in forum Pick & Place MachinesReplies: 4Last Post: 22-10-2010, 03:00 PM -
need someone with cnc brains help
By steveie_e in forum Machine DiscussionReplies: 4Last Post: 08-06-2008, 09:50 AM
