Yes on second thoughts, it looks a much better solution with the modified offset die as the top die.
The yellow line indicates the positioning of the sheet against a back-gauge for a down-stroking press brake, before the press action.
The green line indicates the positioning of the sheet against a back-gauge for an up-stroking press brake, before the press action.
Here instead of adding a base to the modified die, the red area indicates the edge of the top die holder which must be machined off to stop fouling the sheet at a 45 degree up angle.
Here note the edge of the die labelled "L" is at a sloping angle to the vertical. The reason for this is to provide a positioning stop for the sheet (as an alternative or additional stop to the use of a back-gauge stop) to allow space between the corner of the previous bend in the sheet and the edge of the die, to allow for the sheet being pulled in by the bend. The "L" angle shown is for illustrative purposes only. I have not worked out what the angle should be for best results yet.
26-09-2011 #2
28-09-2011 #3
The press brake double V-die tool, the Amada 12206, can be custom modified by grinding to allow the tool to "revisit" previously formed corrugations to allow the bends to be selectively increased to curve or straighten panels.
With the standard V-die, you get one chance to get the bend right because you can't go back and re-do a bend. This modified versatile V-die solves that issue I think.
Amada quoted £226 or $350 extra for the modification in addition to the £127 or $200 for the cost of the standard tool.
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
RFQ: Panels cut from soft plywood
By Rockeyes in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-04-2013, 04:38 AM -
RFQ: MDF Panels (+ More)
By codytom in forum Projects, Jobs & RequestsReplies: 6Last Post: 09-04-2013, 09:16 PM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
