Page 2 of 2 FirstFirst 12
  1. Quote Originally Posted by Jonathan View Post
    Impressive that your router is rigid enough for that. I did mine on the milling machine using the same process and it clearly put a lot of force on the spindle.
    I believe the term is form tool. Not that it's really matters...
    I agree entirely. I found it difficult to get a perfect mesh with the belt. The theoretical values for the pulley blank diameter never seemed quite right.
    I think it is rigid. Whole construction is milled from 6mm thick steel plate + 100x50 rectangular profile. After I paint it I'll make some pics.
    hmm,maybe fly-cutter does not apply entirely. Anyway It's ground from broken end mill to create tooth profile or rather between-tooth-profile . My cutter rests safely and wait for next job .
    Calculations worked for me:
    pulleys PCD radius - 0.381mm gives you pulley radius.
    then cut depth if 1.21mm.
    However I found slight dimensional variations for pulley dia /doc. I used those from pic uploaded
    I have only done XL series pulleys, so trapezoidal not round. Looks like it's easier to get it right with HTD. Should start replacing mine on the router.
    JohnS' makes mine look a bit amateur:
Name:	DSC07946 (Large).JPG
Name:	DSC07949 (Large).JPG
    As those went on my router they've had a lot of use and the pulleys under where the belt runs has got polished. Same is true for the bought ones. I wonder if it's worth anodising them to harden the surface? Would have to be careful not to change the dimensions too much in the process.
  3. Quote Originally Posted by John S View Post
    Doing a stack at the moment.
    These are 5m's
    5M's are a doddle, 1/8" ball nose cutter 2.16mm deep plunged in from the OD which you can get off the HPC website.
    For 3M's you need a 2mm ball nose 1.28 deep.
    That's how mass production looks like
    Very good job anyway. I like the side rings which I couldn't be bothered :whistling:
    Doesn't fly cutter do job faster???
    I ran 300mm/min @ 1.21mm doc and I would dare to do 500 easy. 2mm ballnose could be very flexible as well.
    Again very good looking pulleys, John
  4. Quote Originally Posted by Jonathan View Post
    Does somebody buys the pulleys??? :lol:
    The only issue I encountered was to set mandrel center in RT. After bit of playing with DTI I managed to set it up.
  5. #15
    Quote Originally Posted by wiatroda View Post
    The flanges are nice. You should use 2 to 4 per pair of pulleys, depending on the orientation.
    Ball nose cutter puts less load on the spindle, so less wear? More likely reason is probably that it's harder to grind an accurate 3mm form tool (unless you've got the right equipment) than to just use a ball nose cutter.
  6. #16
    I got a selection of XL cheap on eBay ... other than that, no I don't buy them.
    I did the same. Since it's a 3 jaw chuck I just did the bolts up not quite fully and tapped it into position.
  1. Timing Pulley/Belt sizing software
    By m_c in forum Computer Software
    Last Post: 12-04-2014, 03:33 PM
  2. Increasing timing pulley bore size from 3mm t0 3.175mm
    By divdav in forum Gantry/Router Machines & Building
    Last Post: 14-05-2011, 09:45 AM
  3. 4th Axis timing pulley + Axminster bandsaw review
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 09-04-2011, 07:31 PM
  4. help needed drilling bore hole in mxl timing pulley
    By geekinesis in forum Gantry/Router Machines & Building
    Last Post: 02-02-2011, 01:07 PM
  5. WANTED: Timing Pulley Suppliers?
    By m_c in forum Items Wanted
    Last Post: 02-11-2008, 01:02 AM
