Thread: slaved stepper problems
actually just came in from doing it. the driver obviously has problems. they are 452 drivers, all of them. any ideas what could be wrong with it.
11-12-2011 #2
So just to be clear, the suspect driver works fine except for only going in one direction and the symptoms are the same if you feed it from the breakout board outputs that work with other drivers, and the motor/slaving works if you use a different driver for C?
Is the driver heating up abnormally?
Assuming the above is right, the driver is ignoring the direction input. That implies the opto-isolator inside is broken (so the PGA isn't getting the signal), or something else which will be more difficult to fix. If you want to post it to me I can have a look at it and hopefully fix it, just send me the return postage.
11-12-2011 #3
just tring to get hold of bloke i bought them off to get replacement, refund seeing that they are less than 3 mnths ols. if not i will take you up on your offer. thanks a lot
11-12-2011 #4Visit Us: www.automationshop.co.uk
11-12-2011 #5
3V is borderline, more susceptible to interference, (driver manual says minimum 7mA, 2.99V gets about 4-5mA) yes, but as the same signal works with the other drivers it's less likely to be that. Still it's worth just applying 5V and 0V to the direction pin from a power supply, or directly from the USB +5V to check.
07-01-2012 #6
I've now tested your driver. I connected it up in place of my Y-axis driver. I use *752 series drivers, so they're on 70 volts hence I used a lab PSU set to 48V for your driver. It works fine... I've not done anything to it, just connected it and changed the switches to 1600 step/rev as that's what I use. Then tested it on 800 and 400, not really expecting that to make a difference, and it didn't.
Interestingly the motor runs more quietly and possibly more smoothly (difficult to tell of course) with your driver. I'll have to test my own driver on 48V to see if it's just the lower voltage causing that. If not then that's useful information as it implies they use different control algorithms. As expected though the feedrate I can get with 48V is less (24000mm/min @ 2000mm/s/s acceleration) but still plenty!
So what would you like me to do now? Just send it back and hope it starts working on yours too? I'll have a look inside anyway just to be sure.
tree problems!
By kingcreaky in forum Woodwork DiscussionReplies: 8Last Post: 02-06-2014, 12:35 PM -
Mach3 PC problems, help please....
By Davek0974 in forum Plasma Table MachinesReplies: 13Last Post: 30-01-2014, 07:05 PM -
F-Engrave problems
By cropwell in forum CAD & CAM SoftwareReplies: 29Last Post: 29-06-2013, 03:48 PM -
problems since update
By motoxy in forum General DiscussionReplies: 6Last Post: 02-11-2012, 06:14 PM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
