25-12-2011 #2
25-12-2011 #3
Thanks for the input.
Jonathan....re Z move triggering ....but I need those Z moves too?
Sequence will be like this...
1. Machine moves to first coord
2. Z lowers
3. Once Z is at +0.2MM abovez0 (or similar), the 'trigger' happens.
4. Z raises
rinse repeat.....so I don't see how I can link the solder paste dispense to a z move, else the paste would be dispensed as the z plane is descending.
Jazzcnc ...not sure I'll be using mach3 (I'm warming to the CNC software called USB CNC...and will likely jump over to that .that software allows scripts though, I've coded pics in PICBASIC, so it should be within my ability to lash something up). Not sure I'm understanding you point about the smd components and the reel...I'm not doing pick & place, I just want to get a dab of paste at the centre of each smd pad.
25-12-2011 #4
This is easy with a brain just tell it to watch Z Axis DRO and while ever equal to 0.2 then turn on dispenser.! . . could easily be done with a VBscript as well using something like a While-wend loop.
Ok didn't realise that.! . . . If theres something to probe against then It's very easy to find the centre of a square or circle.
25-12-2011 #5
There's no need to auto probe to get the cnc machine to find the SMD pad centre , my pcb software can either give me those coordinates or I can export the smd pad as a gerber file & import into a cad program & get the cad software to mark the centres of each SMD pad. (which I can then use cam software to use this coords with)
Ok so using this brain melarkey....my z plane lowers & once at say 0.2mm, a trigger happens....but what is the output here? Mach 3 has control of the printer port, presumably once the 0.2mm threshold is breached a nominated pin will change state?
25-12-2011 #6
Yes the brain or script watch's the designated Axis DRO and while ever it's at the commanded position it will trigger the pin state of which ever pin you choose, So say output pin 11 will turn ON and activate the dispenser or relay that controls it. Then when axis starts to move the pin state changes back OFF untill it reaches the commanded height again so on and so forth.
The script or brain can be as simple or complex as you want and really for safety sake you would want it to do some simple error checking IE: only change the pin state if the X & Y axis are not moving etc but in it's simplist form it's a very simple thing to do. Go to the artsoft site and watch the vids on scripts and brains it will give you a quick run down and idea just how simple.
26-12-2011 #7
Ok, thanks I'll go have a read.
The video I was referring to earlier was this one...
http://www.youtube.com/watch?v=HdqVt..._order&list=UL
mounting profile rail - Hiwin Manual vs. typical approach
By dsc in forum Rails, Guideways & BearingsReplies: 14Last Post: 11-12-2013, 10:43 AM
