27-12-2011 #8
Agree John but to be honest I've always found it works out cheaper for small Qty's buying from AW. It seems unless your buying from them on a regular basis as business in decent Qty they load up the price.?
Mike. . . Something I meant to say and partly touched upon before with my material comment and I'm sure others will agree or have found out them selfs while building.?
You have to be very carefull in the design stages that you don't plan on using or design something that hisn't easily available. It's often the simple things that can be a right pain in the arse to source or may not even be available in the intended size or length. IE Timing belts lengths often catch folks out.
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM -
