was a little worried i got it done properly since some parts of the machine i ended up having to use 0.0125mm shims on..
to a tenth of a mm will more than likely be fine, but if id asked for that i might have someone doing it with a hand drill :/
20-01-2012 #2
21-01-2012 #3
Silly question now but why don't you treat yourself to a pillar drill and centre punch and a clamp? at least you would a nice tool to use over and over again. I would not bother to do it any other way except in a drill cycle on the cnc. There does not seem like enough holes to bother setting up for that?
23-01-2012 #4
its a really good idea but just lost my job so very skint :(, its something i'll invest in later in the year when things are back on track..)
i may have made a break through though at the weekend after posting this thread: im trying to get my cnc finished(this job was for one of the last parts) and may well have found a way of supporting the router well enough to do this myself now, im going to give it a go..
thanks to http://www.protocnc.co.uk/gallery.aspx for the message, extremely handy to have found someone fairly locally
wish me luck
Ok PCB milled now how to drill the holes ?
By Fivetide in forum CAD & CAM SoftwareReplies: 13Last Post: 12-05-2013, 08:31 PM -
A silly question on tapped holes
By Philly in forum Tool & Tooling TechnologyReplies: 5Last Post: 11-04-2013, 10:18 PM -
What size clamping holes ?
By dudz in forum Machine DiscussionReplies: 6Last Post: 30-12-2012, 09:10 PM -
Drill 4 x 28mm holes through 44mm thick aluminium
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 30-09-2012, 09:17 AM -
Now if only someone invented a drill that drilled square holes.....
By HankMcSpank in forum General DiscussionReplies: 3Last Post: 20-10-2011, 10:07 PM
