    ok so i got it, apparently times your ac voltage by 1.4... right gonna go with it i think.. been looking at maplins,?
    off the shelf 225va 2x35 3.2a,39.99. not as good as your link to rapid johnathon, i know but what do ya think.
    thanks all
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by crossleymarko View Post
    The proper figure is the square root of 2, which is roughly 1.412, however the rated output voltage of the transformer is with the it under the rated load, so off load the voltage is normally a few percent higher, and you need to allow that mains voltage can drift up and down, so you need to allow some margin for error.
    Also check out http://www.airlinktransformers.com/ for transformers.
    thanks what range of va am i looking at. ie 300va 0-35 0-35
  1. eBay TB6560 Stepper Motor Driver Boards
    By Mad Professor in forum Motor Drivers & Controllers
    Last Post: 22-08-2018, 05:32 PM
  2. Ebay CNC motor kits? Any good?
    By gr8fun in forum Gantry/Router Machines & Building
    Last Post: 01-12-2012, 10:58 PM
  3. eBay TB6560 Stepper Motor Driver Boards
    By irving2008 in forum Motor Drivers & Controllers
    Last Post: 07-04-2010, 04:48 PM
  4. manual for eBay TB6560 Stepper Motor Driver Boards?
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 06-01-2010, 10:37 PM
  5. CNC Kits
    By itbookham in forum Milling Machines, Builds & Conversions
    Last Post: 10-11-2009, 02:56 PM
