Might have this concept wrong so bear with me.
What about scrapping the chuck, fit a collet chuck and just nip it on the work.
Push the work thru the collet with a pneumatic cylinder or even lever feed, stop on the LH outboard end so you feed the same every time.
Drill in a block on the cross slide.
Part off tool in another bock.
Write a program to start spindle, position drill and drill, retract, move to part off, feed new length, wash and rinse.
Basically you have re-invented the sliding head lathe.John S -
16-04-2012 #2
Concept is correct will make a rough drawing ... had not thought of feeding via the collect due to the motor shaft being in the way. http://www.mycncuk.com/forums/blog.php/2916-Bodge
Think I will just take another picture and upload it..
Best Tips for Cutting 6082 Aluminium (CNC Lathe)
By fidia in forum Metal Finishing TechniquesReplies: 0Last Post: 29-12-2013, 07:09 PM -
XYZ 410 lathe
By norm1000 in forum Marketplace DiscussionReplies: 1Last Post: 27-02-2013, 09:20 PM -
RFQ: Who Can Fix My Lathe?
By Chas in forum Projects, Jobs & RequestsReplies: 5Last Post: 18-11-2012, 11:56 PM -
Looking for Lathe Cutting Tools
By Zeeshan in forum Tool & Tooling TechnologyReplies: 2Last Post: 06-09-2011, 09:50 AM -
looking for a lathe
By code r in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 29-12-2009, 07:49 PM
