Took a while but here it is, can you make 'em?
16mmx5 screws with your anti backlash double nuts.
Threads are your usual M12x1, flats are 1mm deep.
I'd like 12mm ball races to slide on by hand, not tight. Other tolearances are fairly slack, shall we say .25mm
best regards
Robin
06-03-2009 #2Visit Us: www.automationshop.co.uk
06-03-2009 #3
Out of interest what are the flats for? Are you fixing the ball screw and turning the nut?
Also 0.25mm is going to be very sloppy on the bearing and may cause you problems?Visit Us: www.automationshop.co.uk
06-03-2009 #4
The flats are for the grub screws that lock the pulleys and handles in place. The nuts hold tension against belleville washers I wouldn't want to rely on them to grip anything.
The tolerance does not apply to the shaft diameter, that wants to be a nice sliding fit. I'm sure you can do better than .25mm anyway.
06-03-2009 #5Visit Us: www.automationshop.co.uk
Congratulations to Gary @ Zapp
By JAZZCNC in forum General DiscussionReplies: 7Last Post: 21-09-2013, 07:44 PM -
Zapp 3-Axis kit - putting it all together
By birchy in forum Motor Drivers & ControllersReplies: 5Last Post: 18-02-2013, 12:05 PM -
10% Discount weekend At Zapp Automation
By Gary in forum Marketplace DiscussionReplies: 10Last Post: 19-02-2012, 12:42 PM -
ZAPP SY60 wiring help
By Smiler in forum Stepper & Servo MotorsReplies: 7Last Post: 07-06-2010, 08:28 PM -
HELP Gary, I'm having a disaster
By Robin Hewitt in forum Linear & Rotary MotionReplies: 3Last Post: 16-04-2009, 10:07 AM
