Page 3 of 66 FirstFirst 123451353 ... LastLast
  1. #21
    yes limited depth of cut to 1.8mm, was 0.8mm so it flat bottoms larger area's. That adden 3 minutes to it according to VCarve at 1min:46
    Simulated it in Mach and got 2 hours 33.
    John S -
  2. #22
    Got it thanks!
    What size/type cutters did you use for it?
    Ian
    I used a simple 6mm 90deg spot drill.
  4. #23
    Thanks again JAZZ. Need to have a look for some of them now.
    Ian
  5. #24
    Just thinking about the spot drill. I have a few chipped single flute 6mm mills. I wonder how one of them would do reground to 90Deg?
    Ian
  6. #25
    Seem to remember that I 200% over ride the feed rate and was maxing out around 800mm/min.!!
  7. #26
    Ian
    Can't see a problem if ground well.? I couldn't belive the results with TC spot drill so if you have the abilty to grind your own then should get great results.
  8. #27
    Just make sure whatever you use is ground to a sharp point. Some spot drills still have a web so you need to be careful.
    I tend to regrind my 6mm single flute cutters back into the same cutter. Something useful to do whilst the router is running.
  9. Ha ha looks like my build log got high-jacked only a couple of days in!! Looks amazing though. Thanks for the further info Jazz and hope your eyes are ok. I will try to get images of progress up in a few days...
  10. #29
    Quote Originally Posted by JoeHarris View Post
    Ye full of pirates and bandit's this place John S being Captain black beard . . " Argh argh yeh bastards who's swipped mi Hobnobs.!!"
    Anyway don't complain too much because when you do have it cutting and wanting something to impress the Mrs you wont have to try remembering which post ya saw that Aztec calendar. . .Lol
  11. Quote Originally Posted by JAZZCNC View Post
    Oh I'm not complaining, just a tad jealous - need to be patient!
There are currently 15 users browsing this thread. (0 members and 15 guests)
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
